Heya all with computex wrapped up i was wondering i want to optimize the fan setup in my Necro build i just completed i need 4 120mm fans and should i remove 1 fan from the bottom and place one in front as a intake instead?
currently shes a toasty box but manages 65c under load on cpu 70c on gpu, want to optimize a good airflow path for this.
1. should i remove 1 of the bottom fans and place one infront for intake instead of having it intake from bottom into the gpu 2nd fan,
2. replace the fan on the heatsink with someting newer then the Gentle Typhoon?
3. replace the top fans with higher cfm fans or just get some industrial ppc?
