Muad'Dib_53
- Joined
- Aug 9, 2008
- Messages
- 56
Any comments on this ~$1000 build?
Here it comes!
Any incompatibilities, or recommendations?
Mobo
ASUS P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 Crossfire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard
PSU
Corsair CMPSU-620HX 620W ATX Triple 12V 50A 24PIN ATX Modular Power Supply 120MM Fan 2X PC *IR-$20*
Memory
Corsair XMS2 TWIN2X4096-6400C5 4GB DDR2 2X2GB PC2-6400 DDR2-800 CL 5-5-5-18 240PIN Memory Kit
Case
Antec P182 ATX Black Mid Tower Case 4X5.25 1X3.5 6X3.5INT No PS Front USB Audio Firewire
CPU
Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB Retail
CPU Cooler
Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan
Video Card
Diamond Radeon HD 4850 512MB GDDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card
Sound Card
ASUS Xonar DX 7.1 Channel PCI-E Sound Card 24BIT Dolby Digital 116DB Snr W/ Low Profile Bracket
HD
Seagate Barracuda 7200.11 640GB 3.5IN SATA2 7200RPM 32MB Cache NCQ Hard Drive OEM *5YR MFR Warranty*
Optical Drive
Samsung SH-S203N Black SATA DVD+RW 20X8X16 DVD-RW 20X6X16 DL18X/12X Lightscribe DVD Writer OEM W/ SW
OS
Microsoft Windows Vista Home Premium Edition 64BIT DVD OEM
Using price match it adds up to about $1150.
I won't overclock in the short term but I'll add a second 4850 in CF when price drops.
What do you think?
I also need a set of good and cheap speakers (2.1 or 5.1?) max 50-70$, any thoughts?
Thanks,
Phil
Here it comes!
Mobo
PSU
Memory
Case
CPU
CPU Cooler
Video Card
Sound Card
HD
Optical Drive
OS
What do you think?
Thanks,
Phil
