Test Setup & Methodology
Testing will occur on a Highspeed PC Standard Top Deck Tech Station and not in a traditional case. This allows easier access to the motherboard for the constant poking and prodding that is required during the reviewing process. The setup remained as pictured during the duration of the benchmarking and stability overclocking process.
As a high-end P55 model, we fully expect the P55-UD6 to have some impressive overclocking capabilities. The overclocking section is definitely the part of our reviews that we take the most pride in, and we spend an excruciating numbers of hours testing, tweaking, failing, and succeeding in order to give you the best possible insight into each motherboard’s overclocking capabilities. After all, if you are anything like us, the overclocking section is the first (and often last!) part that you read when checking out a motherboard review.
For the purposes of this review, our overclocking efforts will primarily focus on three main areas: highest stable BCLK overclock, highest stable CPU overclock, and highest stable memory overclock. However, given the increasing prevalence of automatic overclocking solutions, we have also included an "auto overclocking results" section, in which we will see how good these manufacture-provided technologies really are.
In these overclocking tests we put an emphasis on stability. While the question “What is stable?” could be debated endlessly, we have devised a methodology that combines a wide range of programs that test the stability of the entire system.
Here are some of the applications that will be run in order to validate the overclocks:
Altogether, the above suite should provide enough stress testing to ensure a completely stable overclock, however we are always up for new suggestions. As always, no two systems are ever alike, so your results may vary. Also, overclock at your own risk! The Lynnfield/P55 platform is brand new, and although we are somewhat conservative with our voltage estimates, there is always the possibility that you could damage any and all of your components. If you aren’t fully confident in what you are doing, feel free to stop by our forums and our helpful community will be glad to offer some assistance.
For this review, we have compared the P55-UD6 with the ASUS Maximus III Formula, ASUS P7P55D Deluxe, MSI P55-GD80, and Intel DP55KG "Kingsberg" motherboards, all in stock configuration and using the Core i7-870 processor with Turbo Boost enabled.
We have outlined the five setups in the sample graph above. The orange results are from Gigabyte P55-UD6, purple results are from the ASUS Maximus III Formula, the green results are from the P55-GD80, the blue results are from the P7P55D Deluxe, and the red results are from the Intel DP55KG.
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Intel Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed followed by a defragment and a reboot.
C) Programs and games are then installed followed by another defragment.
D) Windows updates are then completed installing all available updates followed by a defragment.
E) Benchmarks are each ran three times after a clean reboot for every iteration of the benchmark unless otherwise stated, the results are then averaged.
We have listed the benchmark versions above each graph as results can vary between updates. That should about cover everything so let's see what kind of numbers this motherboard puts up in the overclocking section and in our chosen suite of benchmarks.
Test Setup
Overclocking Methodology
- Four/Eight 32MB instances of SuperPi Mod 1.5 (ran at the same time)
- 3+ hours of dual Prime 95 v25.6 using the Stress Testing Blend
- 1 hour of OCCT Auto 1H Medium Data Set OCCT v3.1.0
- LinX 0.5.9 - 25 runs - use all memory
- Multiple loops of 3DMark 06 (30 minutes of looping the full tests each)
- 1 hour of game play in Left 4 Dead & Crysis @ 1680x1050
Benchmark Methodology
