lowerstreet
Member
- Joined
- Mar 6, 2013
- Messages
- 6
I was going to get a NCIX desktop but a friend suggested I get the parts individually. I had no idea where to start so I am beginning with what was suggested in the PC Builder for an i7 desktop which is $1800-ish. I was hoping more for $1500 but I do plan to use this desktop for a few years so I'm thinking maybe I should invest more for a better machine.
Any help would be greatly appreciated since I'm sort of doing this blind.
I want a computer that has quick start-up. I tend to multi-task so speed is important to me... I sometimes watch a video while working on Photoshop for photo-editing with a few internet browsers open for images with some website uploading and file backup in the background. I don't play games too often. Some of my friends who visit play games, so it would be nice to have that option but it's not too important to me.
Around $1800+tax
Canada. I'm probably going to price-match and order/build from NCIX since there are stores near me.
4. IF YOU have a brand preference.
Intel
I will just use my old monitor, keyboard, mouse, speakers.
I've read some, but I don't know enough about the components to know how they would relate.
Default.
I haven't bought any parts yet. I'm hoping to build it once I have the necessary info.
9. What resolution and settings do you use?
N/A
10. Are there any specific technologies you want?
- I would like an SSD to faster boot-up, and to put all my programs on, so the computer runs faster.
- USB 3.0 for sure, but also some USB 2.0 slots.
- In addition, I'm hoping for two 7200rpm hard drives, maybe 1 TB each (or one 1TB and one 2TB).
- A DVD Drive. I'm undecided on adding a Blu-ray drive too... I guess it could be good for storing data on discs, and watching movies.
- I'm looking for a case that is not too gigantic since I'm putting it on my desk. But I don't want the system to overheat or anything, plus I'll need at least 4 slots for SSD, two HDD and one DVD drive. It might be good to have a slot free in case I want to add something in the future. I've never done that before, but maybe I could save money by just buying one HDD now and then waiting for a sale and putting the second one in later.
I'm also hoping for case which is traditional/simple looking. My roommate hosts some out of towners sometimes and I don't want it to be too obvious that there are expensive components inside.
So this was the list that NCIX's PC Builder gave, so I'm using it as a starting point.
Intel Core i7 3770K Unlocked Quad Core Hyperthreading Processor LGA1155 3.5GHZ Ivy Bridge 8MB Retail ($369.98)
Corsair Cooling Hydro Series H40 High Performance CPU Cooler System LGA1366 1155 AM3
120mm Fan ($69.99)
ASUS Sabertooth Z77 ATX LGA1155 DDR3 SLI 3PCI-E16 3PCI-E1 SATA3 HDMI DisplayPort USB3.0 Motherboard (249.99)
Corsair Vengeance Black CMZ16GX3M2A1600C10 16GB 2X8GB DDR3-1600 CL10 1.5V Dual Channel Memory Kit ($110.80)
GeForce GTX 670 2GB GDDR5 2xDVI HDMI DisplayPort PCI-E 3.0 ($429.98)
No power supply
Seagate Barracuda 2TB 7200RPM SATA3 64MB Cache 3.5IN Internal Hard Drive ($109.98)
Intel 520 Series 120GB 2.5IN SSD MLC 25nm SATA3 Solid State Disk Drive Retail W/ Mounting Bracket (159.99)
ASUS DRW-24B1ST 24X SATA DVD Writer OEM Black ($24.98)
Around $1800+tax
Intel
Default.
N/A
120mm Fan ($69.99)
No power supply
