Corsair brand this as a triple chamber design, basically the front half of the 2nd chamber is sectioned off to guide the front fans exhaust out of the right side of the case. IMO, it looks like it's focus on AIO build and you might be able to mount a res. next to the rear exhaust fan. Downside noted in the review is that you can't use 140mm fans and it's pointless to run an air CPU cooler because you can't change the direction of the duct to direct air into the case from the front.
