Overclocking Results
Overclocking the Lynnfield/P55 platform is quite similar to the Bloomfield/X58 platform, but easier since there is no need to worry about the X58 northbridge or QPI Link. More importantly though, since the Uncore has now been isolated from the DDR3 memory frequency, Lynnfield can potentially achieve much higher memory speeds since it is no longer artifically limited by the Uncore ratio. With regard to voltage limits, we really haven't heard anything official, but if you are using air cooling, we recommend that you stay below these values for 24/7 operation: vCore up to 1.40V (cooling permitting), VTT up to 1.35V, and vDimm up to 1.70V. Given reviewing time constraints we haven't stress tested the following overclocks as thoroughly as we usually do, but as you will see we did utilize a healthy assortment of benchmarking and stress testing utilities. Turbo Boost was disabled for these tests, since the constantly changing CPU multiplier would make overclocking significantly more difficult.
Given it's budget-friendly $199 price tag, the Core i5-750 will be the main focus of our overclocking efforts, since we don't honestly expect the i7-870 to appeal to many overclockers given its bloated price tag.
For starters, forgive the missing 'Core Voltage' readout, for some reason it would sometimes disappear on us when we overclocked. Nevertheless, to achieve 4.0Ghz we needed 1.3875V with V-droop disabled. We increased the Uncore/QPI voltage to 1.15V out of precaution, and disabled Turbo, but otherwise this overclock was as simple as raising the base clock (BCLK) to 200Mhz.
We were able to achieve a 210Mhz BLCK, but at this point in time, we aren't entirely sure whether the motherboard or the CPU was the limiting factor. We can load Vista at up to 220Mhz, but any attempt at stress testing would result in a system lock no matter the amount of vCore or Uncore/QPI voltage used.
We were certainly not disappointed on the memory overclocking front, having achieved an excellent DDR3-2100 9-9-9 result. This was achieved with 1.30V Uncore/QPI Voltage and 1.70 Vdimm. We could have tightened the timings, but the Kingsberg board would not recognize the 8-9-8 timing settings, instead defaulting to 9-9-9. This is a shame since our Patriot Sector 5 Viper II 4GB DDR3-2000 8-8-8-20 memory kit was barely breaking a sweat thanks to its top-notch Elpida Hyper BASE ICs.
With Hyper-Threading enabled, the 870 runs pretty hot. As a result, we couldn't safely use as much voltage as with the i5-750 or the temperatures would start hitting 90C mark. Nevertheless, our sample was good for a solid 4.0Ghz at 1.35V with v-droop disabled. We needed 1.28V Uncore/QPI to stabilize this overclock.
This i7-870 was nowhere as BCLK friendly as the i5-750, topping out a mere 202Mhz with 1.35V Uncore/QPI voltage. This might seem disappointing, but given the 22X stock multiplier that would be enough for up 4.44Ghz.
Using the same 1.35V Uncore/QPI and 1.70Vdimm settings as with the i5-750, we were able to achieve a 30Mhz higher memory frequency with our i7-870 chip. I think that most people will agree that DDR3-2138 is not too shabby at all, especially since it represents a 60% increase over the reference DDR3-1333 specification. Keep in mind that there is likely a whole lot more memory frequency headroom with this setup, but we are just being conservative with the Uncore/QPI voltage until we become more familiar with the platform.
