SATA 2 Performance
In a perfect world everyone investing in a new solid state drive would have access to a SATA 6Gb/s controller which could pass on the TRIM command. In reality not everyone has this and for many the decision comes down either giving up TRIM – never a good idea with most controllers – and running it off a secondary controller; or taking a performance hit and running in SATA 2.0 mode.
These tests will consist of some of our real world and synthetic benchmarks run on our standard 1155 test-bed; but the drive will be attached to an SATA 2 port.
For synthetic we have opted for the newcomer to our charts: Anvil Storage Utilities Pro. For real world we have opted for our Adobe test. These two tests should give you a very good idea of the level of performance impact you can expect from running a modern SATA 6 drive in compatibility mode.
As with all the other tests we have performed on the HyperX 3K, the results of the SATA 2 testing show this to be just as good a drive as the original model. By current standards, it seems that drives using SF-2281 with ONFI 2 NAND (be it 3K or 5K) relying upon stock firmware are more or less interchangeable. Simply put, none shows enough of a difference in performance to make it standout from the rest. Custom firmware and newer controllers have simply compressed standard SF-2281 drives into the mid-tier clump that we have today. This is not to say that choosing the HyperX 3K over an original HyperX is a bad choice; rather, both of the drives are solid performers.
SATA 2 Performance
