Wifey is intrigued. Says I'm stupid to even hesitate to go out and buy a couple of these things.
Very, very simple. If you do mine with them, don't forget to get the vBIOS optimized first. A lot of the AMD GPUs, the timings are a mess.Maybe I should put LTC mining as a benchmark in these reviews. Truth be told, I haven't even looked up how to mine with these things....
What do you mean tested at stock? I've tested mine at both stock and overclock speeds before and after optimization. Gives a good ~50Kh/s boost for me.It's simple to start mining. It's not simple to adjust the settings to find the best hash rate.
And that's a special custom BIOS you are talking about. They should be tested at stock, if at all.
With a stock vBIOS, as they come out of the box. And the customized vBIOS from the source you're talking about had no effect on hash rates on my R9 280x but it was already getting near the max rates I've seen reported.
If SKYMTL does decide to do a scrypt mining benchmark, I'd rather they be tested as is out of the box with no customizations or options at all.
