I bought a used Surface Laptop 3 AMD, it looks effectively new. I know it's not the greatest spec-wise as it's the 8GB/256GB model, but it seems like it should be able to run Windows 11 fluidly? This is the custom AMD Ryzen 5 3580U. Instead it's generally laggy overall, decided to run Crystal Disk Info and it says the drive health is 0
Do you guys think I'm in the right frame of mind that it's the SSD causing the slowness? It's really just used to browse the internet, nothing intense.
The only downfall is that of course it uses the tiny 2230 form factor, which doesn't leave many options. Not really looking to spend a whole lot since the laptop was only $250USD, so I was thinking the Sabrent Rocket? Not sure if anyone has a good source of the Toshiba/Kioxia drives, seems to be all 3rd party sellers...
