- Location
- Moncton NB
Time to go back and do them all in B.
T568B is absolutely the modern standard. But the key is consistency. If you have an entire building wired in 'A', then you have to stick to that or recable the building. Going from A to B makes a crossover connection. So if you start patching in 'A', and that patching continues a run from a patch panel that's punched down in B, then you'll end up with a crossover connection. So all-in-all, stick to B.
I think the design for the standard is a carry forward from a ways back when interference could be an issue if the twisting wasn't completed right to the cable termination. (And crossover negotiation wasn't automatic.) You need to make sure that 'like pairs' always terminate together in order to maintain signal integrity. The green pair being split to either side of the blue is done to maintain backwards compatibility. But separating and organizing the colors is always the most annoying part of the cabling work IMO. Thousands of crimps in, and I still ask myself that same question frequently.
Yes but would that matter at all for a cable that's done in A end to end? It's still pin to pin the same output as one done in B?
