This is a fun one that baffles myself. The screen will intermittently flicker. Yea big deal right? screens die, cables wear etc...
Now the isolation,
Occurs in bios
Occurs in OS
Drivers clearly not at fault.
Occurs on power and while plugged in
Not a power draw issue and even then I'm sure I would be getting more problems if it was.
Worn cable? Not likely, I left it idle in the same position and moved it around and it still occurs after being fine for whatever duration... If the cable was in a funky position it should trigger until hinges move and applies the proper connectivity or snaps...
So clearly we point to hardware failure one would think... Sadly Dell are fucktards like every other vendor and you can not force dedicated GPU or the IGPU anymore like I could do on an older Asus laptop I had. Would be nice to force either or to help isolate what is occurring.
Now for the fun last fact,
If I plugin an HDMI as a secondary monitor it is 100% stable. My partner gamed multiple sessions for 6 hours+without a hiccup yet if I turn my TV off, BAM it starts occuring randomly. So that also makes me rule outthe display/cabling at fault. There is no way that level of stability sits in place and returns the second I turn my TV off as the sceondary monitor that is mirroring the original display.
I'm led to believe that the IGPU is no longer engaged when the HDMI is pluggedin and the IGP is failing on the chip... At best you can force a GPU in nvidiaprofile settings but I'm not so sure that takes precedence outside any GPU application and also if I recall even whilegaming it still flickered... Although then I did not force the T500 GPU in nvidia settings.
TLDR:
This is gotta be due to thefirmware update.
I, despite being able to debug the most obscure shit in theworld. Have no idea what is wrong, mostly due this is probably firmware related and I lack insight on the hardware. Anyone else with any insight or debugging idea's would be appreicated.
Keep in mind nothing is OS/Driver related (zero event viewer messages too). I also tried disabling the LID CLOSE feature (I was wondering why the fuck my machine kept turning off when I disabled it in windows and BEHOLD, its fucking hardcoded into the BIOS). The only reason I have this shit device is my workplace was too stupid to coordinate pickup and never responded to my last email after departure... Dell is beyond intolerable in so many aspects.
Now the isolation,
Occurs in bios
Occurs in OS
TLDR:
