Infonec in Mississauga has a bunch of D0 batch# 3845B026 chips in stock. Get them while they're hot!
and they are hot...my 920 from that date code runs hot as hell. 4GHz is stable at 1.187v under load, but it runs as hot as my 965 does 4GHz with 1.4v. i can get 4.2GHz stable with the A/C cracking pretty easy but after that temps are just too high on air. if you are water cooling though, should be great chips if you can keep temps down.Infonec in Mississauga has a bunch of D0 batch# 3845B026 chips in stock. Get them while they're hot!![]()
oh, and they run 5GHz under LN2 with ease :haha:
yeah buddy, don't bother re-seating...there ain't a problem with your mount :biggrin:I agree 3oh6. I have the same 920 as you and the stock Intel cooler is having a lot of problems keeping it below 60, and this is even after reseating SEVERAL times with MX-2 compound. Oh well, I just ordered a TRUE!
Now obviously a WC system would be a whole new ballgame and I would most definitely see the benefits of the DO Chip!:thumb:
it might be interesting to see what a 120.2 can handle with a GTX 295 and one of these hot potatoes.
it is a balancing act. like i said, my 920 D0 of this batch runs 4GHz 24/7 stable at 1.187v under load. my 965 C0 needs over 1.40v to run 4GHz 24/7 stable...but at that voltage, it is running the same temp as the 920 which is using waaaay less voltage, but clearly higher current.What I don't get is how can a chip that runs hotter could be a better over-clocker. Did'nt it used to be that a core-2 chip running cooler at a given oc'd speed had more overall oc potential?
