I don't want triple vga. 2 x vga adapter from the dvi ports and then 1 x active display adapter to dvi from the display port
2 x dvi to vga
1 x active display adapter to dvi for the displayport
so all i need to buy is
1 x dvi monitor that match's my monitor's res
1 x dvi active display adapter
and 1 x 5870/5850
I know that you can not run 3 x vga it needs the dual link for the 2 clock gens:biggrin:
Good luck to all that are trying to run this :thumb:
IIRC.The 2 clock generators are to sync the dual link DVI.
If you go from DVI to VGA then you don't have to worry about the 2 clock generators
Instead of special ordering an $100 adapter from Dell, you can grab the $50 one at your local shop.
Afterthought
What about DisplayPort to HDMI, one of my monitors has HDMI on it
Two DVI plus DP to HDMI?
