FINISHED...
(...or so I thought. Updated photos here)
PSU was a 650, went to swap for 850 and got 1000 for same price
-Replaced Noctua fans with CM R4s -- same (actually better) performance, but at higher RPM
-Replaced stock intake fans (bottom) with Silverstone LED fans and exhaust fan (top) with CM R4
-Wire loom for exposed wiring (front panel lights, HDD LED, power LED, card reader and fan controller cables, etc.)
-NZXT cable extender (sleeved) for ATX power
-Black SATA data cables
It's pretty bright when the cover's off...
...but subdued when the cover's back on. It actually looks far brighter in the photo than in person
SATA cables
NZXT sleeved ATX cable extender.
Specs:
-Intel Q6600@ 3.60 GHz (50% overclock); 1.47V max Vcore, 67C max temp (Prime95)
-Gigabyte EP45-UD3P
-Noctua NH-D14 Heat Sink w/ CM R4 Fans
-Mushkin Blackline PC28500 2GB x 4 @ 1066 MHz
-2x Sapphire Radeon HD5750 (CrossFire) @ 870 MHz GPU clock (23% overclock) and 1160 MHz/4640 MHz effective memory clock (not overclocked)
-3x Samsung SyncMaster 2243 (Eyefinity)
-Sapphire Active Displayport to DL-DVI Adapter
-OCZ Vertex Turbo 120 GB SSD
-3x Seagate Barracuda 500 GB
-LG 22x and Philips 20x DVD writers
-Corsair HX1000 PSU
-Silverstone Fortress FT02B-W
-NMedia CE-Z128 Card Reader
-Scythe Kaze Server Fan Controller
-NZXT Sleeved Fan and ATX Power Cable Extenders
This was my goal for this build -- I feel satisfied that I have pushed my particular setup as far as *I* can get it to go. I'll try to use it for a while without modding it (much) and then start upgrading when I get too stir crazy. The only things on the slate for upgrading are the processor, video cards and motherboard. I actually already have new video cards because I find it hard to pass up a good deal on something that I was planning to get eventually, especially if stock is low.
When my daughter was born I gave up riding/driving/modifying motorcycles and cars (my wife was surely glad to see all of that go). Now learning more about building a system, overclocking, etc. has become my hobby. It's still expensive, but far less-so than the big toys were, and with another daughter on the way, I figure I had better get my "all for me" spending done before the two princesses hit their teens. :doh: I know that I'll get bored if I stop modifying or run out of things to change, so I'm actually not in a hurry to move up to an 1156 or 1366. I'll keep going down the 775 route for now...still lots to learn.
A few shots to show the initial and final builds, as well as what I enjoy most about this setup:
SATA cables
Specs:
-Gigabyte EP45-UD3P
-Corsair HX1000 PSU
