I'm glad that helped. What I meant when I said your temps were a little high is that you should either stop there or upgrade your cooler if you want more overclocking. I disable HT because it requires more power, generates more heat, and I don't use any applications that use more than four cores. If you do disable it, you should notice that the CPU will stabilize at a lower voltage, all while producing less heat. I wouldn't let my i7 reach 80 C, even if that's a reading from your hottest core. That's a little much. On a day to day basis, you will probably want to keep your CPU in the 60 C range max. Another thing I should point out is that if you do turn on the power saving features, you'll want to use a CPU voltage offset in your BIOS instead of simply entering a value for the voltage (ask if you aren't sure how to adjust this- basically it adds a certain amount of voltage to your CPU compared to what the BIOS would normally give it depending on how much load it's under). This is where the real power and heat savings will come in. The last thing you should note is that you'll probably want to avoid load line calibration (if your motherboard supports it) and instead opt to find the right CPU offset to keep your system stable. This is the safest way to run a 24/7 PC.
