A standard HD 7970 is NOT on par with the GTX 760. That's just preposterous. The GTX 760's closest competition is the HD 7950 Boost, a card that's a good 15 - 20% behind a non-GHz Edition HD 7970.
i wonder if this 760 will also change some prices for the amd line as well.
Mh Linus does not have the same results,both 1080p tho,very strange,check out crysis 3...
GeForce GTX 760 1080p Performance Review - YouTube
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/61844-nvidia-gtx-760-2gb-review-3.html
If I had to put my money on it, I'd say AMD will roll out a different / upgraded Never Settle program in the next few weeks.
Linus tests all of the cards at max OC speeds.
Whoops. My bad. Ya I meant the 7950 Boost. But I guess that's expected considering the 7950 is roughly $50 more expensive. Still amazed at the performance difference once overclocked. 7950 absolutely destroys the GTX 760, which is pretty much on par or slightly better than the GTX 660 TI.You mean 7950? Well, 7950 is better to OC because it isn't as locked down as an Nvidia card. Take Linus' review for example (here). The 7950 can almost beat an OC'd 7970 (yes, that's right, 7950 max OC ~= 7970 max OC) while the 760 just doesn't quite have the gusto to make big improvements over its stock performance.
