So wait. I want to be sure I have this right...A card with 81.25% of the TMU's that an 980 has is getting 80% of the performance of a gtx980 at 1440p?
Well then...allow me to retort: As you might know, performance never scales perfectly (1:1) with extra resources, so even worst case we're looking at a perfect example of why this card is performing 20% slower then a card with 20% more TMUs, which is pritty damn ******* close to 1:1, and doesnt show a goddamn thing about it being the memory partition as the culprit, but probably being almost exactly 1:1 performance limited on TMU's and ROP's by 20%.![]()
You do not understand the meaning of that statement. It means when you add resources don't expect perf to scale 1:1. So if you keep GTX 980 as 1x TMU resources then GTX 970 = 0.8125. Alternatively if you keep GTX 970 as 1x TMU then GTX 980 has 1.23x the TMU resources. So in reality even if TMU is bottlenecking the performance and there is a 1:1 perf correlation which never happens btw the real world perf cannot be lower than 0.8125x. But in this case it does. GTX 970 perf is 0.8x if GTX 980 is kept as 1x and if GTX 970 is kept as 1x then GTX 980 is 1.25x. Its easy to see that TMU alone is not the factor at play here and the memory partition is coming to play here.
Those charts say to me the memory bus is coming into play, rather than the memory size. The 290, 780 Ti and Titan all end up surpassing the 970 on the high resolution benchmark, and the 290X surpasses both the 970 and 980. Furthermore, if the memory size was coming into play, you'd expect all the 3GB cards to plummet, but the 780 Ti stays strong and the rest of the 3GB cards gain considerably, including the 780 coming to within a couple FPS of the 970.
yeah that 196 GB/s bandwidth for the first 3.5 GB and 28 GB/s for the last 0.5 GB is at play even though the people who defend GTX 970 are saying its not.
