what fans do you think would make the best configuration while maintaining silence?
I believe it's supposed to be high pressure in and high flow exhaust.
Push Pull on a 212 has little to no effect over 1 good fan.
Did you ever complete this experiment? I'm toying with this same idea for a larger cpu but like what has been said if the 212 is limited by its design it may not be ideal going to a 100W cpu. Let me know your thoughts on this, as it seems to handle a 65W cpu just fine.what fans do you think would make the best configuration while maintaining silence?
I did not, sorry.Did you ever complete this experiment? I'm toying with this same idea for a larger cpu but like what has been said if the 212 is limited by its design it may not be ideal going to a 100W cpu. Let me know your thoughts on this, as it seems to handle a 65W cpu just fine.
hardwarecanucks.com
