clshades
Ohh thats a nice one! its 399 at my store though..
Has an adjustable outlet air pressure. Good feature if you are doing Brad nails. 100psi Brad nails ends up in the next room through the wall lol.
And I got $120 back in Canadian tire money on a $400 bbq recently so watch for those triangle reward bonuses. They need to be activated so keep an eye out.Yeah, never buy tools @ CT until they're on sale.
Case in point.... They've got a reasonably good selection of vices, but they're stupidly expensive unless you're getting them for 50% off (happens at least a couple of times a year).
Those are just too big for me to deal with honestly. The one I linked is very quiet.I bought a used old small compressor on wheels as a 'portable' unit. It has the LARGE motor on the outside with a V-belt driving the compressor. This old style ran at lower RPM and was often MUCH quieter. The new ones use high speed small motors and are VERY noisy by comparison.
Fancy! just a tab bit out of my budget though.There are a series of HVLP spray guns that work off turbines that are intended to operate with higher duty cycles they don't actually have a tank and are basically a vacuum running on blow instead of suck so if it stops running it stops spraying paint. And I don't mean the basic pump driven airless sprayers at the hardware store for painting a house these are inteded to be used with automotive spray guns.
I DO NOT KNOW what the noise levels are like on these style but just maybe this style might be better for your use case. It might also not have the pressure as being a HVLP design (High Volume/cfm - Low Pressure/psi) they may or may not have enough oomph to blow away the chips but may be worth looking into a little closer.
I didn't go looking for the cheapest one possible just the first one I hit that one also includes the gun itself. You would liekly not want the gun laying around and is part of that cost.Fancy! just a tab bit out of my budget though.
Gotcha, ill search around and see what I can find, thanks for the suggestion!I didn't go looking for the cheapest one possible just the first one I hit that one also includes the gun itself. You would liekly not want the gun laying around and is part of that cost.
