Looking to buy a new pc case help smaller the better
syfer
Active member
Hi so the parts are
AMD Ryzen 5 3600 Processor (6C/12T, 35MB Cache, 4.2 GHz Max Boost)
Tuf Gaming B550M Plus WIFI
Arctic Freezer 34 eSports Edition Heatsink & Fan Black & White Intel & AMD Sockets
PowerColor AMD RX 580 8GB DDR5 RED DEVIL Graphics Card Gaming Version (AXRX580 8GBD5-3DH/OC)
Kingston KHX3600C18D4/16GX 4 Sticks 64gb total
Intel 660p M.2 2280 512GB PCI Express 3.0 NVMe Internal Solid State Drive Rev:4.00 (OS DRIVE) (2019/08/09 sticker date)
Phanteks AMP 650W 80 Plus Gold Modular Power Supply
I would like the mini case that will fit my current pc with gpu upgrade later on down the road.
Can anyone help?
Well, the board is M-ATX so there shouldn't be a lot of trouble to find something that will fit a longer card.
You need to give more input on what you need out of a case like Bond007 mentioned.
Cases are so subjective, it's hard to make recommendations without very clear direction on your part.
As far as size goes.... I wouldn't focus too much on finding the absolute smallest case. Super small/tight cases are a niche product and you pay a ton for the right to beat up your knuckles while building in them. :) Even focusing on cases specifically designated as mATX (won't fit standard ATX) aren't necessarily the smallest/tightest. There are several models out there with ATX compatibility that come in a reasonably small package (Corsair 220T is an example).
Glass or solid
I like both but now and the design of the cases are mostly glass.
Lights?
Don't really care about rgb or lights.
Budget?
200 ponds
Colour?
I do like orange and white cases but to be fair i don't mind the colour too much as it will be not out on display too much.
The case must have Type C (USB 3.2 Gen 2, max. 10 Gbit/s) and if possible does anyone have a reverse case ie the back of the case to me at the front as I would like easy access to the back motherboard?
Also as this will be a new motherboard do you think its any point in upgrading cpu B550M?
I built my son's computer in this case. It's smaller than it looks. I managed to cram 2x 240 AIOs in it.
I used the black tempered glass model for a build for my cousin, it was definitely compact in the depth department and the PSU section can get quite tight! It was a nice case though and I'd love to try out more of the Fractal range.
