I’d probably play it safe with the cables as well, those connectors seem pretty picky from what I’ve seen.I recommend against getting an adapter. Get a new PSU that supports 12v-2x6 natively and may be get a 90 degree cable. If it has an adapter then it's either 2 pci-e to 12v-2x6 or 3 pci-e to 12v-2x6. Do not cheap out on adapter, do not plug a single pci-e cable with 2 8pin head into the adapter. Do not tug on the cables and do not make sharp bends with the cable. 12v-2x6 and the older 12 high power have very little margin for power and any lose pins in the head will likely cause a fire.
The problem is that we know there's some kind of problem. All the testings on YT sometimes contradicts each other. We aren't quite sure if it's always user error or cable / connector quality.I’d probably play it safe with the cables as well, those connectors seem pretty picky from what I’ve seen.
