have a 1000 watt ocz power supply, don't really want to buy a new power supply to get a 8 pin connector for the 7970 I just bought. Have it micky moused now using 2 power supply's. the second power supply is just using a 2 pin connection to make up difference from 6 pins I have now. Think it is possible to just cut off a couple 2 pins from an unused 6 pin and use them to make 8? Any idea on which ones should use out of the six? Little broke after buying vid this week so didn't want to buy a new ps.
