Looking at other pictures of this case makes the inside look very tight especially if you want to water cool and keep things (water cooling hidden) thats to bad because I don't mind the looks of this case
Bingo!
Newer batches of 900s come with a crappy cable management system that simply does not work. I wish Antec would simply pull this case until they released its replacement or people would become more aware of the CM 690 by Coolermaster.
Your gonna need a 2 1/4" hole saw if you want good routing in the 900.
To give you some idea, this is a buddies case we modded for the cable managment "properly" in a 900 and it was a pita.
http://www.hardwarecanucks.com/forum/gallery/2492-my-comp.html
I currently have an Antec 900 and I love the case it was easy to work with and to has the best airflow out of any case I have seen, now I am not a stickler for having all the cables out of the way, and with my OCZ Gamestream pwr supply upside down I found that using zip ties and stuffing the extra cables under the bottom drive bay worked really nicely, as well I will eventually probably drill some holes in the bottom to zip tie them down rather then just together. I have had no problem with connectors other than the top audio connector has to go through the middle of the case, I use both onboard sound and my Azuntech sound card, just so I can play a game and have vent through my headset all while having game sound on.
now I actually have a question I am looking for a case that is bigger thanks this one but do not want to lose the airflow that the antec 900 has does anyone have any suggestions
