Applying 3M Di-Noc Carbon Fiber Film
Would a single piece of the 12" x24" cover the top piece of the case (IE top and edges) or would I need a 24" x 24" sheet?
You'll need to measure your case, to determine size of sheet needed :thumb:
I love how this looks! kier's Power Supply with 3M Di-Noc Carbon Fiber Sheet
I've been thinking about different options for mods on my 600t and i really like the look of kier's case. I was thinking of covering the plastic bits with either a silver or white color. I also love the look of that P67 Sabertooth, that thing is just sick looking :)
WTH? lol I haven't used that account forever but somehow it posted under that name... strange indeed :haha:
I have some questions for all the peeps who have used this stuff:
How well does it stick in sharp corners or valleys ?
How easy is it to trim around small holes and other stuff? Do you just use a sharp xacto blade and get a real nice edge? Does it cut easy?
How easy does it come off? Does it leave a residue/mess?
All the stuff I've seen in this thread looks amazing, like factory done. Except for the first example, the iphone. For me the cut out around the camera lens looks hokey, like a home made job. Jagged curves. I know it is very difficult to make a small radius cut with a xacto knife if the material does not cut like a hot knife through butter.
The reason i'm asking is that I am thinking of doing the wood grain part of the dash of my 2011 Silverado over with this stuff. Here's a pic:
Very easy to do most of it but there are some small switch cutouts on the dash and a lot of tight contours and cutouts in the door panel switch plate. I don't want this to end up looking like a high school kid slapped it on his Civic.
Squeeze, the 2 main things with working with this (YMMV this was what I found) is 1: tight corners = heat, get that vinyl soupy and pliable it will take a hell of a stretch before it rips. For corners and round edges this is a must. 2: as you surmised a very sharp exacto knife is needed to cut it, if you use a dull knife then you end up with crappy edging. Lay the product over the part smoothing it as you go, cut the holes from the back side and tbh it is simple, again sharp knife is key. You will also want to make sure the surface is as clean as possible especially on the edges. Get the primer since that will be high traffic area's. For flat non-heavy use spot you shouldnt need it but yeah I would use it for the edging and corners.
Drop by here: Carbon Fiber Film | Dedicated To Selling 3M Carbon Fiber DI-NOC Vinyl
and have a look at the FAQ's and videos, plus IMO better selection, price on larger orders.
