P&S VS DSLR
To DSLR or Not to DSLR that is the question.
(Right after Nikon or Cannon, - think Nvidia or AMD, Ford or Dodge, Harley or -well there is no 'or' for motorbikes).
I bought a Nikon D5100 a few years back and love it. But it is another hobby - and can be as expensive as you want it to be.
Here is a good site to get an biased opinion on Nikon cameras
Nikonians I hang out there and have learned a lot. But it is a steep learning curve. We all start out with the dial set to auto-everything and turn it into an expensive P&S. Then we move past that starting point.
Did a quick check and you can get a D3100 for under $500 with kit lens which is good enough for a while.
For $599 you can get a D3100 with zoom lens
D3100 with Zoom
You may also want to consider used; See
Henrys used section. I've shopped at
Vistek and they are a good supplier too.
You will always wish you'd bought the better camera - I wish I'd gone for the D7000 but such is life. The D3100 is a great starter DSLR and for many people it will last them a very long time. It will take years to master what that camera can deliver - then you'll be ready to drop a few thousand on a new "real" camera. A Nikon D4 is $6000 (body only).
As for software - don't bother with full scale Photoshop for a beginner. Adobe Elements is the entry standard - about $80.00. Corel's version is on sale till the end of the month for $49 (thinking of buying that myself). But there are others for much less that will do. There are good open source free programs that do the job. Just touching up even Googles Pixlr free on-line editor is good enough to get by. But you are right to ask about the importance of the software - that's at least half the hobby. It is amazing what can be done in these photo programs (I use Elements and freebies). At least as much of a learning curve as the camera itself.
Having said this, I used a better quality point and shoot for years before upgrading to DSLR. Look at "Optical" Zoom (not just zoom or digital zoom those terms are meaningless) and megapixels. I'd expect to pay about $200-$300 for a better quality P&S camera with features.
I'd say comparing a P&S to DSLR is like comparing a tablet to a desktop. Both can surf the internet and play games. Depends on what else you want to do and how serious you want to get. IF your interest in photography takes off you'll be upgrading to a DSLR soon enough.
But be warned that is the entry level. I spent $800 on my camera and zoom lens a few years ago and already am eyeing a full frame camera (circa $2900 body only). Upside, you can use your lenses on your next camera (that's part of why I went Nikon, they promise that their lenses will always fit).
But you'll buy flashes (starts at about $350, the pop up one won't cut it after a bit) and gadgets - lots of gadgets, and then gadget bags (I've got three on the go), and filters (these range upwards of $50-100 each) and a tripod (had a cheap one, just bought a better one $300), and my most recent purchase flash umbrellas (cheap on ebay). Looking to get remote flash controllers now ($35) and another flash unit, and a photo-box, and a , and a, anda anda.... don't say you were not warned.
ON the upside there is no film and developing costs now.
Although printing can cost you - both in terms of buying a good quality printer (something that takes six to nine ink cartridges) and printing at the local photo shop. And class 10 SD cards.
And did I mention batteries - the ones for my D5100 are about $90 each! Fortunately they are rechargeable, but you will soon want to have a least two.
you see where this is going . . .
Find someone you know who is into photography, they will love to talk about their hobby.
