My NZXT Case Mod
I just finished modding one of my older PC cases. It actually turned out a lot better than what my initial plan.
I just wanted to cover drive bay, then decided to mod my Power supply bay. I use have my cables all located in the bottom section.
HDD temps have increased slightly. I went from 28 degrees, to 29 degrees Celsius. CPU core temps remained almost the same. I mounted some huge 140mm fans inside, however they only work well if i have the door open. I don't do much extreme overclocking so the temperatures should be good enough.
