So I'm looking into cleaning my case tomorrow and I was considering cleaning my RAM. Current supplies include Cans of Air and a vacuum cleaner. What should I use and how should I clean my RAM sticks (maybe video card.)
Vacuums create static dischage not real good for PC hardware.keep the vacuum far away and just use the air
All drug stores, in Toronto at least, carry 500 mL bottles on the shelf of 99% isopropyl alcohol.You don't want to use rubbing alcohol, it has a additive that makes you sick if you drink it.... that additive leaves a film when it dries. if you can find it you want to get plan old isopropyl alcohol(non drug store). You will pay more for getting no additive, and unless someone knows where to get it in small amounts you buy a life time supply at once.
+1use a paint brush to dust off components.
