Partial and Full Drive Performance
<i>While it is important to know how a drive will perform under optimal conditions, more realistic scenarios are just as important. Knowing if a solid state drive will behave differently when partially or even nearly full than when it is empty is very important information to know. To quickly and accurately show this crucial information we have first filled the drive to 50% capacity and re-tested using both synthetic and real world tests. After the completion of this we then re-test at 75% and 90% of full capacity. </i>
Synthetic Test Results
<i>For our synthetic testing we have opted for our standard PCMark 7 test.</i>
<div align="center">
<img src="http://images.hardwarecanucks.com/image/akg/Storage/MX300/data_pcm.jpg" border="0" alt="" /></div>
Real World Results
<i>For a real world application we have opted for a modified version of our standard Windows 7 Start Up test. Unlike our standard Windows 7 image this image is based on a working system that has been upgraded numerous times of the past few years and represents an even more realistic real world test.</i>
<img src="http://images.hardwarecanucks.com/image/akg/Storage/MX300/data_boot.jpg" border="0" alt="" /></div>
This is one area that Marvell controller based models never excelled at and the next generation NAND does little to help things along. With that said there is a silver lining to these results. While the overall performance drop does cause this model to fall way down the charts, the actual percentage of performance loss is actually better than the previous MX200. Basically this new generation TLC NAND actually responds with planar MLC NAND performance levels, and it is just that this model is slower than its predecessor that causes the drive to fall so far down the charts.
When – not if – next gen <i>MLC</i> IMFT NAND is paired with a more powerful controller the results should be outstanding. In the meantime, we cannot wait to see what this TLC NAND does when paired with a different controller running more refined firmware. We once again do have to question the motivations behind the change in controller as the MX300 LE does not showcase this new NAND to the best of its abilities.
Real World Results
