Grretings all. I would prefer to buy local but it's not necessary. The first item I'm looking for is a 120mmX38mm 3pin fan. Specs needed are 100-130 cfm with decent static pressure. Also needs to be 12V between 0.6A and 0.8A and 2000-3000rpm.
The second item I'm looking for is a 6pin pcie connector with about 2 inches of wire on each pin to replace the toasted white connector (pic below). It was a pita to remove the old connector and the heavy duty pins are still in place on the controller. I don't want to remove the pins. I simply want to solder connector wires to the pins. Let me know what you have kicking around and let me know by PM. I can pay by paypal, EMT or cash if local.
Thanks.
Thanks.
