I just received my new XFX 4890 card to replace my old eVGA 8600GT.
After plugging everything in, I turned on my computer and it seemed to boot fine. After a bit however, I can hear the fan spinning very loudly and my screen goes blank so I need to shutdown my computer. I decide the install the drivers for the 4890 in case that was the problem so I put in my old card to gain access to my computer and install it. Shut down and swap the cards out again and same problem occurred.
I think this card's fan speed is automatically controlled by the BIOS so could that be the problem?
Does my BIOS need to be flashed for it to properly run this card? I checked the XFX site and it did not provide anything to flash this card.
Also while writing this I realised I still had my evga precision tuner installed which was used to OC my old 8600. Now I have uninstalled it and will resume putting in the 4890 again in case it the tool was screwing with my card. Could this be the problem?
Edit: well that was not the issue, I still get the same thing. I am 90% this is a heating issue, could the card have improper cooling? Because the longer I don't use it, the longer it takes to die so around a max of 2mins then the screen goes black and the fan starts spinning like crazy.
Anyway, I'm going to put my new card in again to see if it still spins like crazy and if you guys have any suggestions/experience in how to fix this it would be appreciated. Thanks
All specs are in my profile except for the PSU which is a Corsair TW650w
