Got a HP EliteDesk 800 G4 Mini as my first homelab, running Proxmox VE, with one VM to run my services.
However I’m getting random hard resets every 1-2 days, causing my services to go offline, and having to manually restart the VM.
No kernel panic, OOM, or I/O errors. Just showing “crash” when I run last reboot .
Specs:
So far, have confirmed:
It looks like a hard power-level reset (Logs just stop)
Power brick is 90W OEM HP (19.5V 4.62A).
I’m about to run memtest overnight to rule out RAM.
Has anyone run 64GB in this model long-term and seen similar instability?
Is 90W borderline once you’re running 64GB + 2x NVMe + ZFS + VMs?
Anything else I should be checking before I replace the power adapter?
Wondering if anyone else has issues running these Minis as hypervisors.
Specs:
- HP EliteDesk 800 G4 Mini
- i7-8700T
- 64GB RAM (2x32GB Samsung DDR4 2666 SODIMM, non-ECC)
- NVMe 1: SK Hynix PC611 256GB (OS)
- NVMe 2: Samsung 990 PRO 1TB (firmware 5B2QJXD7)
- ZFS on root
- 90W OEM HP power brick
- Proxmox VE (Debian trixie base)
- Debian VM running:
- WireGuard
- Gitea (Docker + Postgres)
- Joplin Server
- Light homelab services, nothing crazy load-wise
- No OOM events
- No kernel panic logs
- No MCE / hardware error logs
- NVMe SMART clean (0 media errors, no critical warnings)
- Temps normal
- ZFS ARC tiny (~250MB)
- unsafe_shutdowns incrementing on NVMe (suggesting abrupt power loss(?))
