Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Please do not post any links until you have 3 posts as they will automatically be rejected to prevent SPAM. Many words are also blocked due to being used in SPAM Messages.
Thanks!
Well, no. Your connection is sub-par for some reason. I'd say first try your motherboard's LAN and if it's reporting somewhere over 900 Mbps then you know it's something going on with the 2.5G card. If your motherboard lan still reports the low(ish) speeds then there's something going on with your PC and you should check with another PC.
edit: Just to be absolutely clear.... this is an internal network card and not a USB model? If it's a USB model are you sure you're plugged into a 3.0 USB port (Blue)?
