Machine burnt out. New machine needed
I'd get the FTW version if you plan to OC as it uses Digital PWMs IIRC.
Otherwise the normal one will be fine.
The 790i can already OC good, I personally see no reason for spending extra money for little tweaks like that IMO, but just my $0.02
No, no issues, but it would be significantly more expensive for something that is essentially the same product with a few extra tweals. Did I convince you? =D
Well I'd go for it if it was cheaper. but it doesn't seem like it is.
I'm sticking to the GTX 260 because it's at $219 on my current order, unless there are more arguments against it.
So far here are the changes:
How does that sound?
Ah, going for the FTW? I respect your decision nonetheless, build looks allright, personally I would get the C216 version because it's right about comparable to a full-on GTX280, but either way, meh
Hey, well the new machine is finally built.
It's running very nice, and the fans are much more silent than the previous machine.
Again, I decided to go for the vanilla GTX 260 because I got for $219 at the time which was a great deal. Didn't think that adding $120 more for a few more cores was worth it. I got the FTW mobo version with the PWM, for $255. In essence, the best of a well matured architecture.
The next part is to add a decent sound card and the psyko headphones, as well as additional hard drives for a RAID.
