Hi, first of all I'd like to thank you for writing this great review.
I have actually purchased this motherboard before reading this review and have now come across an issue which you mentioned in this review and could use some more clarification.
I have a only one SSD that I wish to install and I tried to place it in the second M.2 slot. Because as you mentioned in your review, the first slot is quite close to the CPU and the first GPU slot so it could have some issues involving heat. Therefore I wish to use the bottom M.2 slot to avoid this issue.
However when booting the computer it seems to be unable to find the SSD. At first i thought that this was a factory issue but then I started googling and ended up on your extremely detailed review. Now I don't completely understand the following bit, but I believe this is at the root of my problem.
I'm too scared to do something wrong so before I try something I'd like to consult with someone more experienced.
To better understand the environment I'm trying to set up I'll explain a little more in detail.
What do you think could be the main cause of this problem and how would you go about fixing it? What ports causes the bottom M.2 slot to stop working or is this not possible when having only 1 SSD and 1 HD? Or do you think I should just place the SSD in the top slot?
standard M.2 drive can be added into this top M.2 port even if both the main and secondary PCI-E x16 slots are already populated. Of course, the bottom M.2 port is not so lucky, but that is why MSI has included two of these future-proof ports for users.
- The single SSD I'm trying to install is: ADATA Premier Pro SP900 M.2 2280, 256 GB SSD
- Next to the SSD I'm have an SSHD installed which is found but might be the cause of problem. As it's connected with by SATA. (Seagate Desktop SSHD, 2 TB)
- The reason I want the SSD in the bottom M.2 slot is because I have a rather large GPU (ASUS STRIX-GTX970-DC2OC-4GD5) above, now I don't know if this might be the cause but just to be certain I thought i'd mentioned it anyway.
