Minor update (weather is just too nice and the motorcycle is calling), and I know it doesn't look like much of an improvement, but I did manage to permanently mount the upper and lower LED strips that go on the "front" of the case. I'll mount 2 more (one upper, one lower) on the "back" side, just because I can.
But mainly I did a bunch of wire routing and a little clean up. Now there is only 1 USB 2.0 line running to the internal hub (instead of one from the MB to the AQ6 and one from the MB to the LED controller) and I plan on running another from the hub to the D5 pump and throw away that ugly Aquabus 'Y' cable I made.
This will mean less connections to the motherboard, but since Aquabus can't do software updates for the Aquacomputer devices and USB can, why not. Also I put some shrink on the HD Audio connector that goes to the case.
Next up will be doing the custom sleeving for the 8-pin CPU power cable, then maybe make a totally custom power cable for the 'dog house'. That cable will need 3 4-pin Molex and 2 SATA power connectors.
Can't wait for the 2 USB3.0 extensions, clear wire combs, and extra long SATA data cables to get here. That will really allow me to clean things up.
