Need NAS Advice
Laquer Head
Calgary/Toronto
So right now my home "cloud/nas" consists of a 2.5" hard drive in a caddy, plugged into the front of my Asus Rt-Ac3200.
Naturally, I have outgrown this ghetto setup, and need advisement on what to pick in a sea of different NAS and Cloud units on the market.
We are pretty basic, I'd guess that a simple 2-bay system would be fine, and a capacity of 4TB is probably overkill.
Not sure if RAID is necessary or even supported.
Are WD RED hard drives the right drives for a NAS setup?
What brands do people recommend?
What type of CPU/RAM/other specs do I want to be looking at?
Max budget would be $1000 CAD tax in for the unit and pair of hard drives
Thanks in advance!
Yes, the usage is pretty much to store our movies, videos, pics, and software to share between 5 computers.
I hear ya on the 4-bay enclosure, even if you dont use em, you have em in case.
As for the drives, would you recommend the WD Red's? or something else?
Thanks for confirming that.
Going a step further from your recommendation, is the amount of RAM important? What about some that have a quad cpu over a dual. Do these specs make a huge difference in a simple setup?
What you are talking about is more like simple storage then a real NAS. Usually when I hear NAS I am thinking a machine running the FreeNAS OS. Which is a bit more complicated. I would just buy a high performance router with a USB 3.0 port, slam a 4TB hdd on it and there you go sharing.
Thats what I have and am doing now..and its slow. I want a faster, more reliable, and more robust setup.
I meant a 300$ dual core cpu router. Otherwise in 300$ you can build your own FreeNAS machine, as long as you don't transcode, even a Core2Duo should be enough.
