Rants etc.....
I buy a new cell phone set up my google account tried to install the backup from my old core lte phone doesn't work .. no bigy I pulled the sim card to put in the new phone the quickly realize that my old cell phone sim card is to large for this phone now not sure if I should see if I can get an updated new one or send the phone back
I think you'll find that the great majority of new phones have the same small sized sim.
What carrier are you with? (If it's koodo I've got a few spare sims kicking around that I could throw into lettermail).
Most new phones come with a usb dongle to swap stuff over.
If you have fairly steady hands, you can cut it to size with scissors or an xacto knife. Lots of templates/how-tos online. Worst case, you go to your carriers store/mall kiosk and get a new one :)
I am going to just take my cell into the local cell store and see if I need to buy a new sim or whatever those mobility cards are call hopefully I can keep my Number apparently there is a way to use NFC i think its called to swap everything over I know so little about cell p[hones and laptop tablets I just fire them up and play around, like laptops I still have issues remembering and using the track pads lol
I've personally managed to do this successfully in the past. :)
Not quite a rant yet, but I tried having a bath for the first time in my house, 2 years since moving in a couple weeks ago. It's a big corner tub, but not hot-tub massive or anything.
Started running out of hot water at about 1/2-2/3 full. I may have ran the dishwasher or done laundry that day so thought maybe it was a bit low. A week later I tried again and it was a the same result.
So today I tried flushing it. I'm assuming the previous owners probably never did it once. Water ran clear almost immediately so I don't think it's that the tank had a massive layer of sediment.
I'm not sure if it's that the tank is just too small or if my hot water tank is nearing the end of it's life. It's probably the original from the build so it's nearing 20 years old.
I might try putting in a new dip tube to see if that's the issue, and will probably throw a new sacrificial anode while I'm at it, but I'm wondering if the old gal just isn't long for this world. Really don't want to replace it, but it might be worth it in the end.
