[Resolved] Computer wont boot..
My HX650w is dead.
Tell me how I go for the $150 power supply with the extra surge protection, and then buy a SURGE PROTECTOR for $40, and the PSU still dies on a surge? I coulda got a shitty OCZ PSU and then just had it die when/if I got a surge.. Sigh.
good news, if the rest of the system is fine. good psu = one that takes a lonely dump AND protects your other components from doing the same.
what surge protector you got again? i usually go for the fugly industrial like ones. and having pc lcd etc chain hooked to a ups helps as well.
ups>surge>conditioner>surge?pc. surge before ups if youre mental like me about it.
I just got a belkin surge protector.. I don't care if its not a UPS it should still protect against surges which it did not do.. zz
they better cover shipping, make some noise(dont expect but just in case. tell them you couldve gotten a 950 watts for cheaper)
<SUP>
psu jumper use the green wire and (blk)ground on the latch side of atx power plug to test psu
for start jump those pins some psu require a load to run also eg. old ide HDD
for start botton short out those pins marked on MB</SUP>
