Ryzen RAM 32gb?
magictorch
I have a Crossfire VI Hero and 1800x but am holding off on the RAM - cannot decide what to get?
I'd like to avoid 2400mhz as likely wont be easy to overclock down the road-would rather aim higher and once updates improve stability run at max rated speed.
Can anyone recommend a 32gb kit upwards of 2666hz?
Thanks..I was looking at the Flare X as a last case....but it seems the higher capacity kits at higher speeds are a matter of weeks away...so Ill take my time with the ryzen build as going for a full watercooling refit of my ~2004 white MM horizon
Availability of Flare X 3200 over 16 GB - G.SKILL TECH FORUM
Just hope these RAM prices stop going skward...the ram is costing more than the motherboard:doh:
