Hi all, I've just ordered a new computer and I'm considering some small amounts of overclocking but I'm not familiar with the process and would like some information on any dangers associated with it. I'm also quite interested in unlocking my processor as well.
Are there certain ranges in which overclocking is allowed by manufacturers in honoring warranties? Or is any amount grounds for denying an RMA? Also, say a 3 core processor is unlocked to 4, is the process reversible - or are you taking risks that you could ruin your processor on the spot?
My processor and motherboard:
Athlon x3 440
Gigabyte GA-MA78LM-S2H AMD760G
...here's my other components incase any other information is needed:
OCZ StealthXStream OCZ500SXS 500W ATX12V 24PIN Active PFC ATX Power Supply 120MM Fan Black
Powercolor Radeon HD 5770 PCs 875MHZ 1GB 4.9GHZ GDDR5 2XDVI HDMI DP DIRECTX11 PCI-E Video Card
Seagate Barracuda 7200.12 1TB SATA2 3.5IN 8.5MS 7200RPM 32MB Hard Drive OEM *3YR MFR Warranty
Patriot Extreme Performance Pgs 4GB 2X2GB DDR2-6400 CL5-5-5-12 Dual Channel Memory Kit
Thanks for the help! :biggrin:
Athlon x3 440
