Aqua Computer AMPINEL GPU power load balancer
moocow
Vancouver, BC
Per Videocardz reporting, Aqua Computer is releasing a 12V-2x6 load balancing device. It's a hardware based solution that detects and rebalance loads for the 12V-2x6 connectors. It will also have the ability to shut down the GPU. In addition to LED status display, it can also send notification email and messages to smartphone. $79 USD or Euros.
Seriously? An ugly giant wart to stick onto your sleep, top-end gpu? 12VHPWR needs to die. Right now.
I slightly prefer the idea of the new motherboard -side power connector, but since they're stupidly standardized it outside of an ITX mobos footprint, its less than ideal either. And obviously, its completely useless for builds that pit the GPU on a riser cable.
If its the adapters that are the problem, I'd honestly go for a compromise I've seen a couple of gpus use: they provide their own adapter, from 12VHPWR adapter to 3x pcie 8pin. And then hide the whole thing.
Example: Sapphire Nitro+ 9070XT1000013988.webp
Which is on this card :
Yes, its 12VHPWR, but since the adapter is provider by the manufacturer, I assume they'd honor their warranty if anything happened while using it. Bonus, the adapter and cables are hidden between the backplate and the passthrough section of the heatsink. Really clean look, AND it can be used in an ITX build!
What I see happening long term is the sharp edges of the heatsink fins and the slight vibrations fo the GPU wearing away at the PSU cable sleeving overtime and wearing down into the wire causing even more havoc.
I thought the issue is Nvidia not doing power balancing onboard and the 12VHPWR cables have very little for margins.
Thread revive! The device is finally released for 100 Euro instead of 80 Euro. But it's showing sold out.
So I built those two PCs for my brother-in-law and niece recently, 5080 and 5070Ti respectively, with dedicated cable for the GPU connection from the new Corsair power supply. Have seen zero issues with their cards, wiring, or connectors. No overclocking in the systems beyond RAM to the XMP (always forget what AMD calls it) profile, nothing for the GPU beyond what came out of the box.
Is this something that you guys would consider adding from a "just in case" mindset? I don't want them to have issues, but I don't want them to waste money unnecessarily on a gadget either of course.
Problems are happening to people with 3.1 PSUs as well. The higher the power draw of the card the larger risk of issues.
Yeah. It is a "just in case" situation I suppose, but a much cheaper option than replacing the card!
I haven't been following too closely, just skimming the posts you guys have made on the issue. Are there other options to mitigate the risk, or is this a unique offering?
