I'm looking for a SFF case that can hold a mATX motherboard that is 175mm or less in width. everything I've found so far is ITX, so no go. it's for a workstation running a 9700X, using iGPU, 64GB RAM and needs space for 1x 3.5" HDD.
tower with a 7" or less width. that's it.Good ol Silverstone Sugo13/14? Could probably find one on ebay, but those put the PSU in the dumb spot right over the socket.
Ive got a few other options in my head, just images I gotta Google and put names to. I dont build as many PCs as I used to... sigh. Will reply again later if I can think of any, but in the meantime:
Any other requirements? Cooling? Desktop orientation vs tower? Odd shapes? Windows? Etc...
IGPU only right? No need for the slots other than the mATX motherboard? If the slots are to be used, half height or full height? Or, Alternatively, a separate gpu chamber IF needed?tower with a 7" or less width. that's it.
yup, using the iGPU, but CPU will be used with heavy load most of the time, so excellent case air flow and room for a solid cooler is a must.IGPU only right? No need for the slots other than the mATX motherboard? If the slots are to be used, half height or full height? Or, Alternatively, a separate gpu chamber IF needed?
