Review Request: Arctic Cooling 13 Pro
CMetaphor
Quadfather
Montreal, Canada
I'd love to see a review of this new cooler from Arctic cooling:
Freezer 13 Pro · CPU · Cooling · Arctic Cooling
Pay special attention to the non-shrouded 50mm fan just above the base of the heatsink, supposedly made to increase airflow around the VRM/NB areas.
Also... 300w cooling capacity? Really?
This is a must-see cooler! HWC! Review it please! :biggrin:
CMetaphor
Quadfather
Montreal, Canada
Maybe, maybe not. 4x 8mm heatpipes is pretty beefy, but it could just be a marketing gimmick.
Still, im more interested in seeing the effect of the open-bladed 50mm fan on the bottom and if it actually does Something. lol
_dangtx_
mtl
well, well see..its probably going to be pretty quiet compared to other cooelrs thanks
to those marvelous fans..
but...open bladed what?
_dangtx_
mtl
oh,right! im blind hahah
brilliant idea. even though itll only affect the next inch or so around it its better than nothing.
downdraft coolers? take a step back!
enaberif
Calgahree, AB
That little fan looks like it would be powered by the airflow in your case or by thermal induction.. really makes you wonder how fast it would spin.
enaberif
Calgahree, AB
Nope! Its powered, judging by the RPM figures listed directly on their site: (Its PWM controlled btw)
Just read the instruction manual on this thing and apparently it uses the same fan header as the cpu.. so the PWM not only controls the main fain but the lower fan..
CMetaphor
Quadfather
Montreal, Canada
PWM requires a 4 pin fan header... only 4 pin I know of on any boards is the CPU fan header.. Unless more boards are coming out with multiple 4 pin fan headers.
Arctic cooling is famous for its "PWM-sharing" tech which allows multiple fans to run off of one 4-pin connector. I'm guessing hats what they're using in this case to control both the 120mm fan And the 50mm at the same time.
