My compact and cheap 4p build I just finished. No more desktop PCs for me, I have this rig and my laptop. It's getting 230k ppd on the 6903 it's working on right now.
Tyan s8812 used
Ebay 6128s
Hyper 212+
32GB Adata 1333mhz cl9
Silencer 910W Silver PSU used
WD VelociRaptor used
Plywood used
= $1525 total after tax and stuff
The PSU is really crammed in at the bottom with the cables tied in place because it's not modular. The board is held on by the the heatsink screws which extend through the board and plywood and have a nut on the back. The nuts clamp the CPU backplates to the wood to help support the heavy CPU coolers without twisting the board. CPUs are at 28-37C with the ones at the back being hotter. There is also an 80mm fan buried in cables by the chipset heatsinks to keep them cool. It's smaller than a case like an Antec 900 but it is heavy with all of that hardware.
To set it up I didn't connected anything but power and ethernet to it and sit on the couch and configure it over IPMI. The sever motherboard takes care of all that for you over the network by running a web interface (like a router) on a special always on chip that you can log into to control the power button, bios settings, temperature and fan sensors, and a hardware version of remote desktop. I also installed the OS over the network without having to touch the server because the web network controller takes an ISO on your pc and makes the motherboard think a USB DVD drive of that disk is attached. I have it set up to start folding automatically on power up with no gui so it is very easy to run remotely.
No big upgrades for me until summer 2013 because of university so I hope it will run stable for months at a time until then. These aren't the high end 12 core ships that get 500k ppd because those are still $500 each but with next gen chips out by the time I upgrade next maybe this board will eventually hit 750k ppd.
EDIT: or not, next gen opterons will be on a different socket, magny and interlagos are as good as it gets for g34
EDIT2: AMD changed its plans again, I hope these Piledriver G34 chips rock
Way To Fold
Tyan s8812 used
Ebay 6128s
Hyper 212+
Plywood used
Way To Fold
