Yes, and I'm leaning toward swapping the artwork to Enterprise-D, to make the overall theme more cohesive. I just havent found the right artwork thats grabbed me..yet :biggrin:
Will loves his RAID array. 9x SSDs will require refining our mounting locations in the Phanteks Enthoo Luxe, which shares same chassis Phanteks Enthoo Pro. Yesterday I modified the Phanteks factory 3.5" cage mounting base to a 2.5" cage with removable trays from a Supermicro S5 chassis. Using this cage will buy me 5 mounting locations (one on side) while clearing our Warp Core. After making all of the appropriate cuts, I scuffed the cage and base with Scotchbrite, applied SEM Self Etching White primer before applying Rustoleum Gloss White Enamel paint. Tentative plan for the remaining Five SSDs is to two mount two on backside of the Phanteks Luxe chassis and fabricate an illuminated shell for remaining three SSDs. This shell would have the LCARS display covers and be mounted behind the 5.25 bay with a window made in right access panel.
Steps in painting parts to match the White Phanteks Enthoo Luxe/Pro/Primo chassis.
1. Scotchbrite surface to promote adhesion for the paint. (Not necessary to remove factory paint)
2. Clear off surfaces with Tack Cloth
3. Apply SEM Self Etching White primer, allow cure for 30 minutes
4. Apply 5 coats in 5 min intervals of Rustoleum brand Gloss White Enamel paint from Home Depot
5. Allow Rustoelum paint to air dry cure for 24 hours before handling
6. (Optional) Apply Matte Clear coat finish to paint.
Prepped surface of the Supermicro PC 2.5" Drive cage for custom White paint with Red Scotchbrite,
3M Scotchbrite General Purpose Pads
