ThE_MarD
Heyyo,
Hmm, also, have you tried using a program like MSI Afterburner to monitor your PC? It might help you figure out if you are GPU or CPU bottlenecked or something else.
MSI Afterburner
For MSI Afterburner?
http://i.imgur.com/l5AEFcL.png
Please ignore the old VRAM doubling bug I was experiencing in an earlier version of MSI Afterburner lol, but as you can see? Each of my GPU's was at 99% to just barely hit 60fps... so I wouldn't have been able to get any higher framerate. So in my case if I wanted more than 60fps? I'd need either a better single GPU or a better pair of GPUs for either AMD CrossFire or NVIDIA SLI.
MSI Afterburner
- Install it WITH the RIVIA Tuner Server Monitoring
- Go into the "Settings"
- Go into the "Monitoring" Tab
- Select the Options you wish to monitor with (such as GPU Usage)
- Select "Show in OSD" for each option you want displayed
- Go into the "On-Screen Display" Tab
- Setup a shortcut keyboard combo (I use CTRL ' as an example)
- Launch the game of choice and tap your keyboard combo set in MSI Afterburner
- Enjoy!
