The Next CRAZY Trend in PC Cases?
Gav
Administrator
Folding Team
Canada
sswilson
Moncton NB
In spite of the issues with the case... I applaud them for trying. Inwin used to be big on looking outside of the box, and now it appears Azza is planning on going that route as well.
Entz
Kelowna
yeah nothing wrong with being different , as long as its not a transformer case :p
That gap triggers my OCD, looks like something isn't working correctly. I have to wonder if a full length acrylic panel (or TG with a solid top) would have been better. That would make the side be "solid" (and show off your hardware) and still have its party trick.
Izerous
Folding Team
Edmonton
If they want to be creative i'd rather see something along the lines of active venting. If CPU/GPU over X temperature open vents to improve airflow but increase noise. Otherwise keep vents closed at sacrifice a bit of temperature but keep noise down (idle state)
JD
Toronto, ON
Wouldn't that make it this then? https://www.thermaltake.com/view-37-argb-edition.html, though I suppose TT's isn't hinged...
At the very least though, that top support bar should have been removable like the Meshify 2 series. Kind of defeats the purpose of an opening top when you still have a bar in the way of accessing your components.
It's an interesting case though.
Entz
Kelowna
Basically yeah . The bottom metal part coming up to just above the PSU is fine its just the gap that gets me lol.
draemn
Fort St. John, BC
I really don't even get the point. They offer nothing of real value or interest except maybe to a very select few with this. Woooo... you can "lift up the hood" like it's a car engine or something?
G
Guest
Guest
Meh why, nothing really seams 100% thought out on this case. And a white ex fan? Like WTF would you use white on this black build? SMH
