Hello,
Case: MASTERBOX TD500 MESH (coolermaster)
Mobo: X570 AORUS ELITE
Been having an odd issue on PC startups mostly when I restart it. Seems that 1 2 or sometimes all 3 front case fans stop spinning after it boots through the BIOS though the RGB still works. (no rhyme or reason with which fan stops, any one of them can make it through the boot)
the 3 front fans came stock with the case and came with a 3 fan splitter pre attached. my rear fan which is plugged into another IO port always makes it through the boot but also stops for a second (corsair fan)
I have since swapped the fan connections with the splitter to no avail and have tried setting the front fans to PWM mode but they run super loud. I have a CPU_OPT connector that is unused, should i try connecting to that and see if the problem wont persist or is it a BIOS setting that is making this happen. the only thing ive changed in my BIOS is activate XMP
I thought this issue wouldnt persist after a BIOS update but it still has.
rest of PC:
Processor AMD Ryzen 5 5600X
GPU EVGA RTX 3070 XC3 ULTRA
Storage WD Black 1TB SSD
PSU Corsair RM 750x
RAM Trident Gskillz NEO 2 x 8 3600 mhz
Cooler Corsair h100i RGB pro xt
rest of PC:
PSU Corsair RM 750x
