Since I can't beat the bots in grabbing a new AMD GPU, I traded my GTX 960 2GB for a R9-290X 4GB. The only problem is that it's a blower style fan that without MSI Afterburner, it would overheat after a few minutes of gaming. When it's using MSI Afterburner, the blower would sound like a running gas turbine engine. Since I'm more or less sitting out this year's hardware cycle, I decided to pay about $120 for a Raijintek Morpheus II cooler.
Box image
Contents (don't remember ordering the black cooler), also come with thin and standard 120mm fan brackets
Post assembly with 2 x 120mm standard thickness fans
It took up 4 slots in my ATX case
I don't know how to benchmark and too lazy to learn. With the fans connected to the motherboard, I'm using the motherboard's temp reading to run the PWM fans (Arctic 120mm PWM flow with build in splitter). It idles around 38C to 40C and hit 72C at 775RPM while gaming with Civ5. With the OEM blower and no MSI burner, it would idle at 70C. I have a PWM to mini 4 pin adapter coming so I can plug the fans to the GPU instead of the motherboard and hope that would give me better control over the fan speeds. Then I'll flip the BIOS switch to performance mode.
Is it a good investment? That depends. If you only have access to a blower card, don't want an AIO, and have an ATX or mATX case, sure. I think it would be better to buy an AIB card that isn't a blower style to start with. Going with an NZXT AIO adapter could be twice the cost when factoring in a compatible cooler.
Box image
