Cannon Fodder
So, a bit of an update. Taking it apart was no problem. Got the spring out, bent it back into shape, but be damned if I can get the bloody thing back in. I must have tried more than 100 times, and tried every combination of doing the front/mid/back first/next/last, but it just isn't happening....Guess I might be sourcing a new switch and doing some soldering...
Well, I DID say it was a finicky process. While it does take me several tries to get it right, it is, however, a LOT less than 100 times. It works best with at least one pair of smallish tweezers, and I always put that tiny, fragile spring back in, while starting from the back. Once you get it back in place for the first time, you'll probably be sittin' there thinkin', "WTF, that was easy as hell.... how come it took so long!?"..... that is, until you do it again. It's just that the spring is so small & thin, which makes it easy to mess it up, and/or drop it.
